Few things - Cylinder heads, injectors, inlet manifold, charger casings, clocks
Started by xrrich, June 01, 2013, 10:27:38 PM
xrrich
Hi Clearing out some of the stuff in the garage.
I have 2 Cylinder heads
1 xG40, valves are out, so will need re assembling, new stem seals and valves lapping in.- £60
1 x 1.3 cylinder head -  from the earlier model with different fuel pump located on the front, has a blanking plate made up to match tho, this is complete. £50
Charger casings -  outlet side is fine, inlet side has damage to apex seals. £40 for good side £10 for bad
1 x G40 inlet manifold £20
Set of original twin belt pulleys with belts £40
set of g40 injectors £30
G40 clocks -  spares or repairs -  i forgot what was wrong with it i think it was the mileage numbers £10
Rich
harrison
Quote from: XRrich on June 01, 2013, 10:27:38 PM
Rich
hey do you still have the g40 head?
westy02
