anti roll bar to work with arb blocks
Started by z3i, May 25, 2013, 05:19:03 PM
z3i
My nylon arb block is slowly being eaten away by the lateral clamp on the ns, it doesnt sit straight, as there is not enough room. ive been reading and alot of peeps have the same problem, however there is another antiroll bar people are using that is flat and still misses a 4 branch. Can someone tell me the exact model this came off and the gearbox used
thanks
RyanC
I have this same problem, as the bend on a 5 speed is very close to the ns arb block so you cant fit the clamp parallel to the block. I have seen people using 4 speed arb as u can fit the clamps straight but haven't payed to much attention to clearance of the manifold would be interesting to know what the solution is maybe using a 4 speed arb is the way to get round it?
z3i
Yeah, after doing 1000 miles on it the lateral clamp starts to eat into the nylon
4 speed you say? Wonder if it clears all the extra stuff on the g40, wonder if they are the same
the one i saw fitted to a car was pretty much all flat, might have been a 4 speed one
metz
Mine are on straight, i just spun the dohnut looking clamps until the allen bolts face the front of the car and they sit flush to the arb blocks
Should look something like this (metz's car):
I usually find it easier to drop the TCA away from the chassis, and leave them bolted to the ARB loosely, get the ARB aligned with the blocks and clamps central, then fit the TCA into the strut, then fit it into the chassis.
There's 2 types of 5 speed ARB - was a thread on club polo a while back about it. Both of them fit (obviously) but one has the clearance offset from the centre, no idea why!
metz
Do you usually need to threadlock them pete? mine were about 6inch away from the blocks the other day just rattling about. :D
z3i
Yes! Thats the arb i need, its another 5 speed one then, will have to keep my eye out at the breakers
Quote from: metz on May 29, 2013, 09:37:08 AM
A dab of 243 loctite will do mate, don't put too much on otherwise you'll strip the head if you need to take it off  :)
metz
ah ok,good advice or i would have bathed them in the stuff
RyanC
i alway thought that was a 4 speed arb in that picture? as my 4 speed bready has that style on it and all 5 speeds have the g40 type i didnt know they were all called 5 speed just two different types? ill try fit it again if all fails ill swap the 5 speed for my 4 speed bready one :)
z3i
Quote from: RyanC on May 29, 2013, 08:24:43 PM
Theres always 4 speeds in the scrappy near me, may get a few incase anyone needs one on here
