G40 parts for sale
Started by Poloace, May 23, 2013, 10:11:15 PM
Poloace
Hello All,
I am so busy at the moment I don't think I will ever have time to do anything with these, with a bit of work someone can  build up a G40
I have all the basics for a G40 conversion, that needs and engine rebuilding and a cylinder head (you could use a GT or a MH head I have a G40 cam) to complete, the following prefer gone as a complete set,  as I don't think I will ever get time to use them.
Stock G40 charger 69K rebuilt but never run in all charger brackets in very good condition came from an unmodified car and has never had a smaller pulley fitted, Stock V belt pulleys,
All ancillaries from 69K car ( alternator starter motor clutch)
G40 bottom end, needs a rebuild, no cylinder head ( have G40 cam) The block has done 170K ish the pistons were all  good, however bores may have some minor corrosion, crank is good and not yet been ground so all good for a rebuild.
G40 inlet manifold and throttle body, injectors, ECU ( choice of chip).
G40 gearbox (170K), that needs a new syncro fitted to 2nd and working polo 16v gearbox that will fit MK2/Mk3  ( boss removed for the 6N gearchange)
G40 engine loom, fuel pumps, all boost pipes, intercooler
G40 Driveshafts
Polo Mk2/Mk3 Lower strut brace,
£650 ono
Located near Newbury in Berkshire
07876244823
