Front speaker cover
Started by metalblue, May 22, 2013, 07:07:53 PM
metalblue
I'm guessing it just comes off...which way do I pull it? Straight up? Don't want to damage it
z3i
On a mk2f? They just clip in, shouldnt be tight at all
metalblue
Yes fella 2f. It's not tight and looks like it will lift up with a bit of force...just don't want to break anything
Jacque
should come out real easy indeed, just try to lift the front (closest to you) with your fingers. that should do the trick, if not, try a flat screwdriver for some extra lift
