Dump Valve issue
Started by Etches, May 13, 2013, 07:19:27 PM
Etches
Another issue here, wound my forge actuator rod up abit from 0.5 bar and each time i build the boost pressure up my forge 007p seems to dump even on throttle. Obvs I need to take it off and have a look , maybe change to a stiffer spring but I've had 1 bar of boost with the same valve. Has anyone had any similar problems with there Forge 007p? The vac line is on the front of the tb for reference.
Etches
Vac feed to DV needs to be post-throttle body.
Etches
Ah! Stupid me haha, I used to have it on t-piece cheers man
metz
easy fix  :D
You at lowdown meet on monday tom?
Etches
Yeahman I will be, dunno wether it will be at 7 or 9 though as I have to wangle leaving work early
