Author Topic: misfire & oil pressure  (Read 962 times)
Offline chris2911
« on: May 05, 2013, 07:45:38 pm »
hi me again starting to get the genesis ready for the season but ive got a electrical breakdown misfire when you stay at a steady rev fine when idling and fine on boost.
I've got the ECU coil distributor off my red one on it
standard working injectors
any one got any ideas what this could be
what is the oil pressure on a G40 meant to be I've just fitted a oil release valve
idle from cold 40-50 psi
revving up to 70- 80psi
idle when hot 11-20psi
does that look about right
thanks in advance
