Author Topic: ATV gearbox with Quaife LSD - best oil?  (Read 2930 times)
Offline vwnut
« on: February 25, 2013, 11:11:48 pm »
My ATV gearbox has been returned after a service and fitting the ATB Quaife LSD.
The guy who did the work  recommended using Dextron 2 Automatic gearbox fluid as the best fluid / oil to use. Seems a bit strange to me for a manual gearbox?
What is the best option for smooth gear changes, a quiet gearbox and long life?!
Don't want to bugger it up after all the hard work.
Offline dub-disaster
Re: ATV gearbox with Quaife LSD - best oil?
« Reply #1 on: February 26, 2013, 08:08:16 am »
quaife recommend standard original vw gearbox oil,that's what i use in mine. Torsen diff dont require special oil unlike plate diffs.
« Reply #2 on: February 26, 2013, 09:22:48 am »
I would go with whatever quaife say!
Offline josé
« Reply #3 on: February 26, 2013, 01:28:56 pm »
I just used the standard gearbox oil vw recommend in mine
« Reply #4 on: February 26, 2013, 02:00:04 pm »
should be ok for a quaife but in case anyone with a different diff reads this, ask whoever makes the diff what to use as some (plate types) need different oil.
Offline jez1272gt
« Reply #5 on: February 26, 2013, 05:21:00 pm »
Yep make sure that you use the VW recommended stuff with the Quaife unit. Wont be the same for different manufacturers though so always check...
Offline vwnut
« Reply #6 on: February 28, 2013, 11:18:07 pm »
Thanks for all the recommendations - standard VW recommended stuff it is!
Thanks again.
Offline mark_crox
  • www.mk2polo.co.uk
« Reply #7 on: April 28, 2014, 02:12:36 pm »
Thread bump.
Need to fill up my ATV box with a Quaife fitted. The standard VW oil for the box is G 060726A2 but the VW dealer doesn't know the specs of it. Is this oil really the best thing to use? Its £4.95 + VAT per litre btw :)
I did mention Quantum Hypoid but its not listed as the oil to use.
Offline RyanC
« Reply #8 on: April 28, 2014, 04:44:46 pm »
I'm sure it's 75w80 or 90
