Author Topic: How to connect boost switch [Inside TB]  (Read 4131 times)
Offline AdzCM
« on: February 03, 2013, 06:17:59 pm »
I've seen this roughly explained on other threads but I still don't follow clearly.
Do I connect the brown/yellow wires to the boost switch then leave the other 'idle' switch the way it is? Or what do I do with it?
Adrian
« Last Edit: February 04, 2013, 12:54:06 am by AdzCM »
Offline AdzCM
Re: How to connect boost switch [Inside TB]
« Reply #1 on: February 05, 2013, 02:58:06 am »
Anyone?
Offline Etches
  • Still got the G...
« Reply #2 on: February 05, 2013, 09:20:39 am »
Its just the full throttle switch you cut and wire into the pressure switch dude, i can get you a pic of mine if you want?
Offline dub-disaster
« Reply #3 on: February 05, 2013, 10:37:34 am »
yes it is those two wires you have to switch
Offline AdzCM
« Reply #4 on: February 05, 2013, 11:30:40 am »
No need for a pic if its just those 2 wires you connect to the boost switch :) but thanks anyway.
Thanks for that guys.
Offline jez1272gt
« Reply #5 on: March 05, 2013, 04:18:22 pm »
Is there any specific orientation between these wires and the boost switch? I assume not...!?
« Reply #6 on: March 05, 2013, 08:07:50 pm »
you assume correctly! :)
