How to connect boost switch [Inside TB]
Started by AdzCM, February 03, 2013, 06:17:59 PM
AdzCM
I've seen this roughly explained on other threads but I still don't follow clearly.
Do I connect the brown/yellow wires to the boost switch then leave the other 'idle' switch the way it is? Or what do I do with it?
Adrian
AdzCM
Etches
Its just the full throttle switch you cut and wire into the pressure switch dude, i can get you a pic of mine if you want?
yes it is those two wires you have to switch
AdzCM
No need for a pic if its just those 2 wires you connect to the boost switch :) but thanks anyway.
Thanks for that guys.
jez1272gt
Is there any specific orientation between these wires and the boost switch? I assume not...!?
