Author Topic: 65mm pulley  (Read 1855 times)
Offline AdzCM
65mm pulley
« on: January 30, 2013, 12:15:36 am »
I am selling this due to my turbo build.
Full blend PSD charger [maximum ported] with all the banjo bolts [for oil feed/return] and other necessary bolts for the dome, mounting plate and pulley etc.
NOTE: Charger has only done 1500miles since last rebuild so its basically like new. Been lubricated properly with correct PTFE spray.
Inlet collar/blanking plate/large filter/intake pipe and 65mm pulley. Belts will be sent along with pulley although a fresh set would be advised.
£350 inc. postage for the charger.
£25 for the pulley
£15 for the intake pipe + filter
£10 for the inlet collar
« Last Edit: February 13, 2013, 08:39:10 am by AdzCM »
Offline Jezza-7
Re: Full Blend Charger etc.
« Reply #1 on: January 30, 2013, 08:20:26 am »
Would you sell inlet pipe and filter separate?
Offline AdzCM
« Reply #2 on: February 05, 2013, 06:41:42 pm »
Bump
Charger is seriously cheap at that?
Want it gone...
Offline AdzCM
« Reply #3 on: February 07, 2013, 07:24:01 pm »
Charger is SOLD :)
Still for sale:
- 65mm Pulley
- Air Filter and Pipe
- Inlet collar
Offline Jezza-7
« Reply #4 on: February 07, 2013, 11:08:00 pm »
I pm'd about collar, inlet and filter.
Offline AdzCM
« Reply #5 on: February 13, 2013, 08:38:17 am »
Inlet collar, air filter and pipe sold.
65mm pulley left...£20 posted
Offline krazy*k
Re: 65mm pulley
« Reply #6 on: March 25, 2013, 06:57:07 pm »
is the pulley in good nick ?
