Long story short, went to start my G40 the other day after doing a bit of work on it.
When turning the key to start, the motor did not turn and all that could be heard was a few relays clicking under the dash.
Tried to bump start to no avail. Tested for permanent live supply to motor - present.
Tonight I brought a supply from the battery straight to the solenoid, and the starter motor turned over at a decent speed.
Did the spark plug test, and getting no spark when turning over.
Is there any connection between the two symptoms? What I'm thinking so far is the ignition switch, there is another symptom that the heater blower is getting a supply, but will not allow the motor to run, however link the motor straight to the battery and it does run. I get continuity between the multiplug of the heater motor to the switch.
Thanks in advance for any advice.
