G40 track project
Started by P1rik, December 31, 2012, 01:08:05 PM
P1rik
That Would be great thanks is there any shows on Soon that you are going to Be at
P1rik
P1rik
P1rik
Hopefully it will make a big difference
z3i
That pedal box is the sex!
How much was it if you dont mind me asking?
hydro brake, cable clutch and throttle
taylor
P1rik
It was about 350 mate bit expensive but hopefully it will do the job
Etches
Looks awesome mate, get loads of pics up how you end up doing the clutch master cylinder etc :)
z3i
Quote from: etches69 on May 28, 2013, 07:27:04 PM
+1!
£350 is good! A mate of mine paid twice that for some german made one
Nice pedal setup- how are you planning on setting up the master cylinder / bias (presume from the balance bar you've got 2 cylinders?)
Liking this  8)
P1rik
Yea I have got two master cylinders behind the peddle box and the reservoirs will go under the bonnet linking them to the cylinders with braided hose
Sorry, I was thinking more about what size cylinders (not sure what your pedal ratio is?) and how are you plumbing them, presume 1 to front 1 to rear, but some people prefer a bias valve to a balance bar (although you can adjust both on the move)
Good work  ;D
samuel.cole
samuel.cole
shit thats alot!
any other makes that are cheaper? or similar shifters?
