Name that part!
Started by Andy, December 28, 2012, 06:36:59 PM
Pint to whoever can tell me what this is and where it goes!
It's probably an interior part, and likely to be part of the dashboard; heater blower unit or steering column assembly.
Found it in a bag of bits from the bodyshop, and I've no idea where it goes! Sadly there's no part number on it so I can't look it up on ETOS/ETKA etc - so I assume it's part of a larger assembly.
cheys03
No idea! But knowing that bodyshop, it's probably off a Ford that was also having a restoration at the time ;)
DKnight
i am 99% sure it is part of the steering column, where the 2 shafts slide together, will fire etka up now...
DKnight
no sign on etka but it defo goes there, there is a recess cut out on the shaft where it sits if i recall too...
i agree with dk, not with his morals but with his part knowledge
Is it some kind of knuckle duster?
Cheers dudes! Any chance of scribbling on the ETKA photo where it's supposed to go please DK?
no - but between two collapsingbits of steering column
Was obvious once I pulled the column apart.
Fits here:
Showing it in position:
And another shot showing it sticking out the end of the upper section of the column:
