What lowering springs?
Started by fil_rite13, November 21, 2008, 09:28:32 PM
fil_rite13
Like a cock i was all set to put my G40 up for sale, however after driving it again after over 12 months i want to keep it. Problem is i sold my H&R cup kit (along with other tuning parts) so my plan now is for some -40mm lowering springs on the stock G40 dampers. I'm planning on running 14" alloys and was looking at eibach spings. Does this sound like a ok combination or would i be just as well off with some budget lowering springs?
At -40 you'll get spring dislocation using the standard shocks. Some folk don't seem too bothered but you might get an MOT fail if the examiner spots this. Best go for a complete kit with shortened damper rods.
packers
thanks for information but am running on aftermarket shoks at moment problem is the springs are too low and too hard great on a race track but around the potholed roads of south yorkshire a bit too jarring
packers
Hi sorry about inappropriate reply clicked on wrong line by mistake and afraid dont know how to delet it apologies packers.
supercharged spaniel
i personally would invest in the H&R cup kit again..it really is a great all round kit..if you can afford it that is.
G-spot
I've been on standard replacement OEM shocks and Eibach -40mm springs for well over a year now and personally I find them a great combination, I'm toying with loosing an extra 10mm on lowering caps, but will wait til I fit my subframe to see how it effects the set-up.
Gary
i've got a set of eibach springs that a was thinking of putting up for sale if your interested?
jimbugalee
If someone above isn't interested I might be.
Ty for thread, thinking of lowering my G and can't remember what I did to my last one!
Fred
 H & R Cupkit, are these the correct ones ? how does the bottom of the front strut s fit, it`s just that they look different to standard
http://www.vwspeed.co.uk/volkswagen/vw-parts/86_86C_Polo_H_R_Cup_Kits-1730-173.html
that looks like a generic photo, not specfically mk2/3 polo
Fred
#10
 Thought there wer summat a miss there Pete. Any body got Pics or a Link
to Pics of the correct H & R Cupkit ?
That pic of you there Pete looks suspiciously like your looking at a Guitar
Neck. lol
breadman
There is nothing to really see looking at a H&R Cup kit. They look the same as the normal stuff regardless of make, if they didn't they wouldn't fit!
The H&R springs are black and the inserts/rear struts are silver.  ;)
The springs are obviously stiffer and shorter than the OE ones. The rear struts have an abutment stop on the body for the lower spring seat to sit against. If you fit the spacer provided it raises the spring seat by 20mm, hence you have the option of 40 or 60mm lowering.
The front damper inserts have a shorter piston rod to match the shorter springs.
The H&R Cup kit is exceptionally good gear. :)
However, if you just want to replace the springs, you could do a lot worse than buy the Eibach ones. Eibach is reknowned for making excellent quality components, and I've never had a problem with spring dislocation on 40mm lower springs/standard length damper rod suspension.
Fred
Food for thought there Breadman as i`de already bought the GSF Lowering kit
but after reading of spring dislocation on standard shocks it put me off fitting
them.
breadman
As I stated, I've never had a problem with 40mm lower springs on standard dampers.
