Starting issue
Started by krazy*k, October 21, 2012, 06:00:33 PM
krazy*k
Me again :) G has been running sort of ok since its been in but i have one problem which I'm sure you guys will be able to help with.
When the G is cold its starts a treat but once its been driven and warms up when i go to start it, it takes ages to start sometimes the battery light will stay on so i just give it a little bit of throttle and the light goes out. I have also noticed ( easier when its dark) that the battery light flickers this is very occasional tho, my digital clock also resets itself i sat watching it the other day and it reset itself 3 times when the car was running.
We have checked the battery and all seems fine even tested it when starting the car with the multimeter
Cheers in advance :)
AlexG40
You can rule out the battery by using jump leads from another car so start it when it's warm. The battery light staying on after starting and going off with a little blip of throttle is a bit of a G40 foible.
youngprodigys
sounds like alternator to me! the D+ is excited by the bulb in the dials- if its a poor circuit then a blip of the throttle will send the voltage through to excite the D+
you can check this by crudely putting a wire from the positive terminal on the battery to a bulb - then from the bulb to the D+ wire on the alternator.
id start after this cleaning up the contacts on the alternator- the connector at the inlet manifold and the fuse to the dials in the fusebox
