Author Topic: Stage 2 ppp subframe  (Read 14613 times)
Offline z3i
Re: Stage 2 ppp subframe
« Reply #30 on: June 26, 2013, 10:03:30 pm »
took the servo out and master cylinder this evening
didnt find much, a bit of rust but no obvious holes or cracks
when i push with my hand it flexes a little so its not very strong
will be getting the rack off tommorow evening
what do people recon to reinforce it?
many thanks
Offline z3i
« Reply #31 on: June 26, 2013, 10:11:00 pm »
Should i start a new topic for this?
Offline Andy
« Reply #32 on: June 26, 2013, 10:17:59 pm »
Mine had a hole where one of the spot welds was above the master cylinder hole in the bulkhead. Is your battery tray area all solid?
Offline z3i
« Reply #33 on: June 26, 2013, 10:23:20 pm »
battery tray had a hole in it, but it was all welded up
Offline z3i
« Reply #34 on: June 27, 2013, 08:57:36 pm »
Got the rack off today, lots of surface rust but no holes or cracks
other than grind the rust off and treat it, what should i do to reinforce it? would stitch welding the seams support it much?
also my rack is very nothcy, is this normal, and the damper has resistance but it doesnt feel like that much
sorry to keep annoying people with this, just want to get it sorted, appreciate any help
