Daily G40- Windsor Blue L-Reg
Started by Yoof, September 10, 2012, 07:41:25 PM
z3i
I hope so, your asking price is a bargain too!
Well, i tried a length of silicone hose and because its at a slight angle and it kinks the pipe. so after some searching i found one of the german sites (bar tek) i think do the ribbed one but its 80 euros. after more searching i found a length of silicone ribbed hose that looks fairly similar to original but was £50
with the original ones getting pretty old now they are perished from expanding contracting, hot/cold and constant oil contaminants. mines well worn out. give me a shout if you manage to find any decent ones that fit and aren't really expensive
also thanks for the info on the place that sells the little connectors :)
Taylor
I used silicone in the end Taylor, fits well and means all the boost pipes are new and in silicone hose now, so no rubber to perish.
Almost ready to fire:
Last few new bits arrived, new lambda, gearbox oil, and a new alternator/starter wiring loom from VW.
Should be ready to fire on Monday  :)
Tav
z3i
fancy a swap for my G and money your way? :D
Now running, tappets need to fill back with oil (take a few hundred miles) but all sounds sweet.
Needs a good clean now, then ready for it's new owner  :(
For sale thread: http://www.polog40.co.uk/forum/index.php/topic,9654.0.html
Taylor- I've no room mate, otherwise I'd keep this!
randombadger69
Excellent Work Pete!
Nice to see you caring for a G40 and steering it back onto the OE path!
How much was the Alternator wiring loom out of interest? (just about all my small block vw's need one of these!).
