Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Engine and Transmission
low coolant light
« previous
next »
Pages: [
1
Go Down
Author
Topic: low coolant light (Read 979 times)
packers
low coolant light
on:
August 22, 2012, 05:13:06 pm »
Hi been having this problem on and off for around 2 weeks .low coolant light starts flashing for no obvious reason suspected bad connection but cant pin it down anyone any ideas.
Re: low coolant light
Reply #1 on:
August 22, 2012, 05:29:23 pm »
could be low pressure? When was pump last changed?
Could replace tank as the sensor could be faulty. Only like £12-£15.
Administrators
The CV joint killer
Reply #2 on:
August 23, 2012, 10:01:06 am »
probably the level sensor in the header tank, new tanks aren't expensive.
packers
Reply #3 on:
August 28, 2012, 05:32:54 pm »
Hi fitted new expansion tank very reasonable 10.25 from gsf but the light continues to flash does anyone know if the wireing goes to the dash board or to ecu not very clear in haynes manual
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
low coolant light
