Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Superchargers / G-Lader
Any ideas?
« previous
next »
Pages:
1
2
3
Go Down
Author
Topic: Any ideas? (Read 11592 times)
Justin14100
Traders
Re: Any ideas?
Reply #30 on:
August 24, 2012, 11:12:12 am »
A G60 throttle is totally different, its got two butterflies in it much like a polo GT, and I think the primary throttle is actually smaller than the G40 one.
Justin14100
Traders
Re: Any ideas?
Reply #31 on:
August 24, 2012, 11:21:29 am »
Also there wouldn't be any point in getting anything bigger than 57mm as that is the size of the engines intake pipework
Re: Any ideas?
Reply #32 on:
August 24, 2012, 11:22:14 am »
Indeed.
Oh well i never knew that.
Administrators
The CV joint killer
Re: Any ideas?
Reply #33 on:
August 24, 2012, 12:55:28 pm »
depends if you are using the standard intake pipework! Which I'd have thought not if you're modifying to the point where the throttle body needs to be bigger than 51mm.
There's also the possibility that if using after-market management you can get better throttle control using dual butterflies. Andy does the same on his although I think he's using parts from an NZ engine.
Pages:
1
2
3
Go Up
« previous
next »
Club G40 Forum
Technical
Any ideas?
