injectors
Started by fat joe, August 07, 2012, 01:33:43 PM
fat joe
Hello there polo people I was wondering if anyone can help me
I have got myself some injectors to use in my turbo set up
0280150465   258cc   12.0ohm I believe they are from a 150hp 20v turbo
I've got the chip for 250cc green g60 and 6psi switch
What I want to know is can I use the injectors stated above?
Cheers joe
hard to say really.  It's pretty close to the flow rate so it might work ok.
but different injectors have different characteristics too.  Ones with multiple, smaller pintles will behave differently than ones with single, bigger pintles.  With a single pintle, you generally need more fuel at idle and low loads as the atomisation isn't as good.
you might need some tweaks making to the map but then this is highly likely anyway unless your turbo setup matches exactly what the chip was done on.
