Fuel pump relay
Started by Gilly, July 30, 2012, 07:37:50 PM
Gilly
Hi all, need a fuel pump relay part no: 321919505A   i cant get one anywhere, tried main dealer and all motor factors. Has anyone got a spare or know where to get one? Its a 5 pin and mk3 polos are different. HELP?
youngprodigys
join the queue, theres a few adverts including my own in the WANTED section section
Gilly
Nightmare, someone needs to get manufacturing them, Bosch dont even do them!!!
youngprodigys
ive worked out how to make my own- but without knowing what size diode was used i cant guarantee it wont set on fire hahahaha :-(
youngprodigys
i found those aswell, all american based though. i suppose buying a few would be better- i wonder how many people would be interested if i ran a kind of group buy?
POLOMON
I would have a couple Kiz, spares an that....
tez
I'd take one as a spare as well, better safe than sorry!
Etches
I got one from my VW in sheffield was 30 for both of em
POLOMON
Would you be able to get part numbers?   ;) Please
youngprodigys
ive been told at 2 different dealers they are obsolite.
Fred
Mine failed in my Genisis a month or so ago so when i turned off the ignition the pump carried on running.
I suspected the pump was going but a gentle ish tap on the relay stopped it. I later found that if i turned back on the ignition and off again
then that stopped it.
I called at mates Garage (CBS Auto`s) who specialises in Mazda MX5`s
and it turns out they have the same part.
Of course it has a Mazda part number on it but the multi meter said correct.
Works 100% and is identical internally.
I should think quite a lot of cars from around that time will have used the same item.
Fred.
dubface
Quote from: Fred on August 25, 2012, 07:04:10 AM
Fred.
ah but the 1.3s have stock relays - gt/g40 have one fuel pump relay - one ecu (which is now obsolete)
just to say MAXRPM now do these - I have a trade account so I can supply if anyone wants one?
