Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Technical
Engine and Transmission
Idle Issues
« previous
next »
Pages: [
1
Go Down
Author
Topic: Idle Issues (Read 1197 times)
SteG40
Idle Issues
on:
July 16, 2012, 10:04:27 pm »
I've run out of things to try, can anyone shed any light on possible causes for this. Basically the engine won't idle at all, the only way to keep it running is to have your foot on the throttle. It starts everytime and idles briefly on cold start but if you blip the throttle it won't come back to idle just cuts out. I've changed things like the ecu, dizzy, fuel pump relay, fuel pressure reg, plugs, changed the ignition timing doesn't make a difference were you set it, still cuts out.
I've done a quick vid so you can see what it does
http://www.youtube.com/watch?v=9D_UXgN-qf0&feature=youtu.be
Ste
AlexG40
Re: Idle Issues
Reply #1 on:
July 17, 2012, 12:00:16 am »
Check your engine earths are all on properly.
Check your blue temp sender and lambda probe.
Mine had a similar issue which turned out to be a faulty wiring loom.
SamG40
Administrators
Take.... on.... me....
Re: Idle Issues
Reply #2 on:
July 17, 2012, 09:00:30 am »
Earth by the charger is a vital one. The car will hardly run without it.
Traders
I know naathing..
Re: Idle Issues
Reply #3 on:
July 18, 2012, 08:30:04 am »
Idle switch?
SteG40
Re: Idle Issues
Reply #4 on:
July 20, 2012, 01:28:08 pm »
I've checked the earth's, all ok, blue temp sender is brand new too. The idle switch, should you be able to hear it click when it's working? The WOT switch clicks but the idle doesn't.
Ste
Pages: [
1
Go Up
« previous
next »
Technical
Idle Issues
