Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Chassis & Braking
can anyone help with this?
« previous
next »
Pages: [
1
Go Down
Author
Topic: can anyone help with this? (Read 3543 times)
djtez
aaAAHH CHOOO!
on:
July 15, 2012, 12:53:00 pm »
i know there is a readily available kit for the MK1 golf.
but my question is which Caliper here is the one used in the kit.
can anyone clarify bore size, disc width (closest i see is 21.1mm)
thanks for any help
Traders
I know naathing..
Re: can anyone help with this?
Reply #1 on:
July 15, 2012, 04:23:01 pm »
You talking about the Wilwood 4-pot kit?
djtez
aaAAHH CHOOO!
Reply #2 on:
July 15, 2012, 04:33:51 pm »
A am such a tool a forgot to link it
Yes yoof, wilwood set.
Trying to figure out wat calipers they are as but separate ad my own discs an pads an make the kit cheaper
djtez
aaAAHH CHOOO!
Reply #3 on:
July 15, 2012, 08:18:44 pm »
http://www.rallydesign.co.uk/product_info.php?cPath=562_588&products_id=8317&osCsid=cjo2apcom01f8p796ek8762oa1
these are the caliper's ...
this is the Kit .. .
http://www.rallydesign.co.uk/product_info.php?cPath=562_563_577&products_id=4012&osCsid=cjo2apcom01f8p796ek8762oa1
Now i have noticed the Mk2 golf kit being alot cheaper? i dont understand why and it also offers 74mm lug spacing! ...
is it a different offset?
Traders
I know naathing..
Reply #4 on:
July 15, 2012, 08:32:54 pm »
It's the midilite caliper, the Mk2 golf one is probably dynalite (non dust sealed) so cheaper?
I can't remember what size the piston are, I've got the paperwork with caliper part # on somewhere though, if I find it I'll scan it in for you.
djtez
aaAAHH CHOOO!
Reply #5 on:
July 15, 2012, 08:39:30 pm »
thats very helpful thank you!
i plan on getting the adapter plates and my own discs and hope to have wilwoods alot cheaper..
djtez
aaAAHH CHOOO!
Reply #6 on:
July 31, 2012, 06:49:48 pm »
think i have the part no now for this
part no. 120-7471-m16 (m12 mount holes)
midilite 4pot caliper.
Please anyone who are running these, can you tell me what the mounting brackets are, if you know dimensions or which one they are...
£149.50 x 2 calipers
£49.80 mintex m1144 pads
=£348.80 + VAT = £418.56
plus a set of golf discs are £60 = £480 roughly!
where as the kit would be £438.90 supplied with plain discs + vat = £527 ....
Where as the if a bought the kit would be slightly dearer and i wouldn't have the option of buying Grooved discs or better quality discs than supplied..
maybe your thoughts ?
Traders
I know naathing..
Reply #7 on:
August 01, 2012, 01:09:32 pm »
I went through the same thing- and ended up buying the kit from rally design, and using Brembo discs (grooved) I gave the stock 256mm ones to Andy.
Might be worth ringing them and see if they'll knock some money off if you don't order discs.
By the time you've made the brackets and had them coated and got fittings/fastners I'd just buy the kit for the pennies you'll save, at least if it breaks (not brakes) then you'll know who to blame!
djtez
aaAAHH CHOOO!
Reply #8 on:
August 03, 2012, 07:40:31 pm »
Well biting the bullet and looking at the Kit, also Pete's Hi spec's up for grabs..
but the adapter has been shimmed down to fit 239's
might have to play a bit. maybe buy new adapters if possible
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
Chassis & Braking
