Roof lining help
Started by matthg40, June 12, 2012, 10:04:47 PM
matthg40
Evening all need some advice I brought my g off a dude as a rolling shell and the rear of the roof lining is a mess it has all peeled away and is to short because the clown has cut it for some random reason.so my question is does any one know a decent adhesive/glue I can stick the lining back down with as what I have used so far has failed thanks all matt
AlexG40
I used the heavy duty spray adhesive from Halfords. The trick is to let it go tacky before you put the two surfaces together. Sticks like a limpet.
If the lining's not reaching the hatch, a strip of black duct tape (pretty tacky) stuck to the lining,lets you pull the lining reasonably tight and still isn't too noticable.
