Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Electrical
Oil light buzzing
« previous
next »
Pages: [
1
Go Down
Author
Topic: Oil light buzzing (Read 3721 times)
Gilly
Oil light buzzing
on:
May 30, 2012, 09:32:32 pm »
Hi there, did an oil change and also changed dash loom for a new one but now the oil light is buzzing but only when revving, has anyone has had this problem?
Administrators
The CV joint killer
Re: Oil light buzzing
Reply #1 on:
May 31, 2012, 09:54:08 am »
is the dash loom from the same age car as yours? The wiring changed later on and there's only one oil pressure sensor on later ones.
Gilly
Reply #2 on:
May 31, 2012, 11:07:08 am »
dash loom is from a 1994 polo on a k reg, my polo is a 1991 on a h
Administrators
The CV joint killer
Reply #3 on:
May 31, 2012, 11:15:11 am »
yes then the loom will be from one with a single pressure sensor. You'll need to clocks to match really. Or run your own wire from the 2nd sensor to the correct pin on the back of the clocks.
Gilly
Reply #4 on:
May 31, 2012, 11:19:05 am »
excellent cheers for your help, ill run a wire from the second sensor to the clocks
Administrators
The CV joint killer
Reply #5 on:
May 31, 2012, 11:28:25 am »
I think there's a pin-out diagram for the clocks connector in the electronics FAQ section somewhere which will tell you which pin to use.
Gilly
Reply #6 on:
May 31, 2012, 11:33:34 am »
got it, pin 24......cheers for putting that up, a great help
Gilly
Reply #7 on:
May 31, 2012, 03:11:58 pm »
hayesey, which switch do i run the wire from? ones a high pressure and one is low?
Administrators
The CV joint killer
Reply #8 on:
May 31, 2012, 04:28:27 pm »
not sure off the top of my head. Have you got a haynes manual there? See which sensor goes to which pin on the back of the clocks. The wires from the sensors go directly into the clocks.
RyanC
Reply #9 on:
July 31, 2012, 07:19:42 pm »
My g40 dose that when u rev it up the light and buzzer gose on and stays on, loom is original :/
ereeiz
Reply #10 on:
August 02, 2012, 06:07:44 pm »
Checked the sensors to see if they're working? From memory one is for <2.5k RPM and the other for >2.5k RPM, although that may be mk2 golf.
Someone had that on here not long ago and turned out to be a dodgy set of clocks. Everything fails sometime!
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
Electrical
Oil light buzzing
