Where to buy a new distribution ?
Started by hipgrave, May 22, 2012, 08:40:42 PM
hipgrave
As above .. Needing a new one as mine has died. Any Ideas where to get one ?
distributor?  Not sure if VW have any?  It's basically the same part as a 6n 8v uses so I'd imagine VW would have them.   I use a 6n one on mine.  It's a later one (from a multipoint injection engine), the earlier single point 6ns might be different.
supercharged spaniel
gsf used to sell bosch repair kits so you could basically overhaul the original.  If you buy from vw you're basically buying it to get a fresh case.  The kit when I bought it was around 50 quid.  That was about 4-5 ago though.
