Author Topic: bearing/damper housing top cap tightening tool  (Read 5312 times)
Offline dub-disaster
« on: May 22, 2012, 11:12:55 am »
Right,
  what's the correct tool to torque up the top caps of the damper housing ? And where can i get it from??
Offline scotsjohn
Re: bearing/damper housing top cap tightening tool
« Reply #1 on: May 22, 2012, 05:06:16 pm »
Usually a C-Spanner of the right Dia. for external caps, but gentle tapping round with a soft metal drift usually gets them into place.
« Reply #2 on: May 22, 2012, 07:36:44 pm »
are we talking about the same top caps?? I can't see how you could use a c-scanner as its completely round and smooth its got what looks like a large hex cut into the top but i can't see how you would use a hex key as the damper rod/piston would be protruding from the hole.
« Reply #3 on: May 22, 2012, 11:43:49 pm »
ok ive made a tool now out of a driled out nut and some 6mm bright steel  :)
« Reply #4 on: May 23, 2012, 09:37:08 am »
a vice :D
Offline prankstar2003
« Reply #5 on: May 23, 2012, 07:31:23 pm »
Stilsons
Offline cheys03
« Reply #6 on: May 23, 2012, 08:51:30 pm »
a vice :D
This!
What's the correct torque? Bastard tight.
Are you worried about a few dents from the jaws? Fuck no.
Vice it is then!
:D
Offline Jaco2a
Offline gavin.starr
« Reply #8 on: May 24, 2012, 02:16:50 pm »
Im about to throw everything around the garage in a min, that little castellated nut at the top of the strut will not move.
Is there any other way than gas torching through the strut rod to get the strut out of the suspension arm. Im trying to get my new TA technics suspension on. and so far not so good.
Im getting seriously fecked off so and ideas. Ive tried a set of good pipe grip pliers on the large nut that has been mentioned above but that wont budge either.
« Reply #9 on: May 24, 2012, 02:25:57 pm »
i've used a chain whip and a rubber mallet before. digs in well for the cup to get the damper out.
As for the castle nuts... i recommend the proper tool and done on the car with it on the floor!
Offline scotsjohn
« Reply #10 on: May 24, 2012, 03:40:16 pm »
Laser do a cheapo socket for VW/Audi castelated nuts, but not a good fit iirc. If you're fitting new inserts, cut the old rod with an angle grinder; job done. You'll still have to shift the top caps on the struts though and if you cant find any key points for a c-spanner then as suggested, delicate use of a stilson
Offline gavin.starr
« Reply #11 on: May 24, 2012, 04:03:28 pm »
Done it I set fire to the bugger. New insert in fitted and installed to the car.
Now to get on with the other side.
« Reply #12 on: May 24, 2012, 04:08:57 pm »
I cut through the piston rod with an angle grinder once when I couldn't move the castle nut.
Offline youngprodigys
  • G 3URO
« Reply #13 on: June 02, 2012, 09:10:40 pm »
you can make a castle nut from a thin spark plug socket as it has the hex on the top - it shows you how to in the haynes manual!
Offline Robin
  • 194bhp - 1341 Turbo
« Reply #14 on: June 09, 2012, 10:48:46 pm »
LOL!
Now that doesn't suprise me!
I am battling with the castelated nut on one of my dampers, the fucker is being a right arse, had to destroy as much of the top mount as i could to get the vice jaws on it.
