Front Mount Fitting
Started by AdzCM, May 02, 2012, 03:27:46 PM
AdzCM
Been searching on how to fit a front mounted intercooler and I can't seem to find anything. It keeps getting asked but with no replys.
Im in the middle of fitting mine and was wondering how you would pipe from the intercooler exit to the throttle body?
Piping from the charger to intercooler entrance is easy but I don't know how id go about fitting the rest since the radiator is in the way.
Should I mount the radiator further back to allow for the pipe to come up over the top of the it?
Brainstorm, any ideas are welcome :)
Adrian
vwmk3jon
Its usually just a case of buying afew bits of pipes and seeing what works as there isnt any off the shelf parts so to speak. My IC is mounted infront of my radiator and i have no issues with the rad being in the way. i only had to trim some bodywork in the enginebay to get the boost pipe to fit.
AdzCM
Quote from: vwmk3jon on May 03, 2012, 11:01:02 AM
Did you pipe over the top or round to the right of the radiator. My radiator is tight up against the right hand side of the car and I don't think I could notch anything there... Where abouts did you have to trim? Would you have any pictures? if not, its no problem...
Cheers mate
djtez
In my case, moved the radiator along, pipe squeezed in the right of the radiator.
not much angles or piping needed to fit this .
think a 90, straight, 45, little straight and onto the cooler.
SFS , samco , rallydesign , sgt-motorsport.. many sites will supply pipes and agles needed
AdzCM
Quote from: djtez on May 03, 2012, 11:54:25 AM
Cheers mate, have more piping than I need here. Ill see how much I can move the radiator across. Pity the charger has to be so much in the way.
G40jamie
Ive piped up from one side of the front mount to the Charger, but still havent really found a good route to pipe the otherside, just gonna get loads of bends and see what happens :)
usually end up having to move the radiator out of the way to get a pipe down there.
vwmk3jon
sorry, forgot about posting here!! i'll post up some pics later ron to show you.
vwmk3jon
Got a pic.
if you look, youll see my radiator sits abit further back allowing the intercooler to sit infront, allowing room to run the boostpipe up the side and joins to the black plastic standard boost pipe with afew extra pieces of pipe (including a reducer as the piping im using is smaller than the standard piping).......
