Author Topic: Charger to Intercooler Hose  (Read 3636 times)
Offline Robin
  • 194bhp - 1341 Turbo
« on: November 09, 2008, 10:48:05 pm »
Chaps
I am trying to get hold of a samco or similar make hose to go from the charger to the intercooler, the current one is just a straight pipe and keeps popping off due to BOOST...............
Does anyone know where i can get one from or what dimensions i need?
Offline GSBellew
Re: Charger to Intercooler Hose
« Reply #1 on: November 09, 2008, 11:15:20 pm »
Most people will probably tell you to use a 45 degree elbow pipe.
Personally speaking though I would only use a VW one.
In my opinion the accordion effect of the OE VW pipe is required to prevent straining the intercooler. It absorbs the movement you get between the charger and intercooler. the charger moves relative to the intercooler (which is bolted to the body) as the engine rev's change and the engine moves on its mounts.
Offline Jake
« Reply #2 on: November 09, 2008, 11:17:16 pm »
pretty sure its 57mm internal diameter. think some people use silicone 45 degree bends. I've bought a meter of marine exhaust hose because its a little flexible. Its corregated and good for 3 bar of pressure. Could sort you with some of that pretty cheap if you were interested...
Offline DKnight
« Reply #3 on: November 11, 2008, 02:52:10 pm »
