Oil Coolers...how big is yours?
Started by gofasterpinch, April 15, 2012, 10:32:17 PM
gofasterpinch
Just doing some shopping for the project and need to acquire an oil cooler.
I'm running a fairly tweaked AFH on bodies and other bits.
i was thinking of either a 10 or 13 row, 235mm wide to sit next to the rad, where the stock intercooler would be on a G40.
does this sound suitable?
Alex
Etches
gofasterpinch
do either of you have a gauge fitted and know what kind of oil temps you're getting with them?
Alex
I have a gauge fitted, but it's not wired up to the sender. ::)
Etches
Mines currently sat in my outhouse :) , 13 row is plenty mate . Its going to be cool enough with one of these , 13 row is what psd used ?
cheys03
13 row, 235mm. Temp. measured at the sump, never gets above 120* with a turbo.
Quote from: cheys03 on April 16, 2012, 02:24:38 PM
Same, except I got mine to 135°C on track. Radiator is still stock CL though and I'd got the water temps so high the water overtemp buzzer was coming on.
gofasterpinch
ah that's good, considering you guys with the turbo applications should be seeing higher oil temps a 13 row should be ideal for mine.
is a 235 the right width to fit in that gap?
