Liam- normally this would cause the pads to clatter, potential problems with dirt/grit/stones coming between the pad face and disc, and a long pedal (potentially need to be pumped).
However, you can get pressure valves which fit in the brake line and keep 5psi or so on the caliper (braking pressure is well into the hundreds of psi) which would close the pad gap up, and hopefully stop the above problems.
Vauxhall discs are also 4x100 (centre bore 56.6mm) and different offsets to VW ones, so there's some potential there for you too.
