Author Topic: torque settings? engine making concise document for engine rebuild.  (Read 3107 times)
Offline supercharged spaniel
  • GRRRRRRR
I've put together a full table of every part for the block and head for a full rebuild excluding electrical/sensors (ill do a seperate one for those)  it would be good however if i could get the torque settings too and add this to the sheet.  Then i'll email it to hayesey who hopefully can put it on here as a downloadable document?
i was thinking  torque settings for:
head bolts
crank bolt
fly wheel bolts
main end caps
big end nuts/bolts
sump bolts
rocker cover bolts
and any others that available?
engine only please
Offline Alexiskayak_7
Re: torque settings? engine making concise document for engine rebuild.
« Reply #1 on: November 08, 2008, 04:03:36 pm »
Oh... I have  Autodata book that writes in there... I'll send you the torque of these bolts in Monday...
« Reply #2 on: November 12, 2008, 05:28:04 pm »
The head bolts are bolted with that way:
 10 4 2 6 8
  7 5 1 3 9
Main bearings: 1st stage 33NM 2nd stage 65NM
Big end bearings 1st 30NM 2nd 90 degrees
Flywheel bolts 25NM
Camshaft pulley 6NM+ 90 degrees
