Stealth Racing Polo G40 RR day 17th October 2004 Results!
Started by Karlos the jackyl, March 30, 2012, 09:44:07 PM
Karlos the jackyl
Ok .. very very late results  ..  8 years overdue ! , I stumbled across this paperwork  while tidying  .. however better late than never.
Enjoy!
Reg: J5
Modifications: Stage 4 Charger, Dewedged , K&N , Cat replacement
Estimated Power: n/a
Actual Power (BHP): 118@5706
Actual Torque: 119.6@3300
Operator Comments: Power a little bit low , woth checking valve timing.
Owners Comments: Little dissapointed , now its no longer a dailey driver I will have time to fix
Reg: J8
Modifications: G40 1341
Actual Power (BHP): 194@7699
Actual Torque: 159@4241
Operator Comments:  Low down pinking . however very good power
Owners Comments:  Ditto 
Reg: A9
Modifications: Stock
Actual Power (BHP): 136.5@5846
Actual Torque: 132@4029
Operator Comments: Good!
Owners Comments: n/a
Name:  Paul Borthwick
Reg: J2
Modifications: G40 full blend , 65 mm toothed belts , stage 3 head , aquamist
Estimated Power:  170
Actual Power (BHP): 170.4@5515
Actual Torque: 164.5@4877
Operator Comments: Tested in 5th gear , too much wheelspin in 4th , bad low down pinking , good power and torque
Owners Comments: Same as last RR figure , happy!
Reg: J4
Modifications:  Flowed charger , forged pistons , 65mm pulley, full stainless exhaust . skimmed head, K+N filter, 1341 toothed belts
Estimated Power: 160 / 150torque
Actual Power (BHP): 164@6992
Actual Torque: 145@4010
Operator Comments:, lots of wheelspin on first run Tracking needs setting ip
Owners Comments:  Happy with this as a first run
Reg: H4
Modifications: Full Blend, toothed belts, cosworth intercooler, GT manifold, water injection, twin inlets, Poloace chip
Estimated Power: 160/130 torque
Actual Power (BHP): 160.7@6406
Actual Torque: 142.7@4633
Operator Comments: Good power , water injection usefull
Owners Comments: happy with that but needs more work
Name: Richard Klienhans
Reg: L6
Modifications:  Stuff and things
Estimated Power: ?
Actual Power (BHP): 192@6619
Actual Torque: 168@4900
Operator Comments: Too rich at top end , could make more power
Owners Comments: That'll do , Someone lend me a charger!
Reg: M3
Modifications: Pitstop full blend, toothed belts, repofiled cams, decat , Ashley exhaust  dewedged. Pitstop induction kit, custom chip
Estimated Power: 160/155 torque
Actual Power (BHP): 156.3@6964
Actual Torque: 131.2@3500
Operator Comments: Good power , very good torque considering high mileage
Owners Comments: not bad for 158,0000!!
Reg: D2
Modifications:  Toothed belts , full blend, 1341 , big vlave head, piper cam, dewedged, big intercooler
Estimated Power:  not sure
Actual Power (BHP): 167@6800
Actual Torque: 145.5@5500
Operator Comments:  Good power but very rich
Owners Comments: Not bad , i was hoping for a little more, boost leak possible cause.
Reg: PT
Modifications: ZG block , digijet , GT cam + inlet , g40 exhaust
Estimated Power: 60
Actual Power (BHP): 90.8@5977
Actual Torque: 81.4@5775
Operator Comments:  A real wolf in sheeps clothing
Owners Comments: Well pleased , car only had 40hp ( 895cc)  from the factory
Reg: H3
Modifications: R1 , Big valve head, cam , bigger TB ,P&P inlet and exhaust manifold, 65mm toothed , decat  aquamist
Estimated Power:  166
Actual Power (BHP): 177@6306
Actual Torque: 151@5084
Operator Comments:  A little rich , coolant temp switch fault
Owners Comments: I had 166 before methanol injection so quite pleased.
Reg: G4
Modifications: PST toothed belts , full blend
Estimated Power: 125+
Actual Power (BHP):
Actual Torque:
Operator Comments: Too low to run
Owners Comments: Damm!
Reg: K2
Modifications: Induction , filter
Estimated Power: 113
Actual Power (BHP):
Actual Torque:
Operator Comments: Diagnostics good, Non runner tracking out
Owners Comments:
Reg: K5
Modifications: 1341 cc rebuild, full blend, 68mm pulley
Estimated Power: 150/145
Actual Power (BHP):
Actual Torque:
Operator Comments:  Pinking very bad needs immediate attention before engine lets go.
Name: Paul Cauldwell
Reg: J7
Modifications: 1308 and other things that are race spec
Estimated Power:????
Actual Power (BHP): 176@6652 (178)
Actual Torque: 156@4415
Operator Comments: Exhaust blowing a little bit , possible hampering power
Owners Comments: Disappointed with power , needs setting up badly and have itself a good day
djtez
lots of comments on pinking...
could all be using the same mapper ?
i have old pictures of Andy Boakes white G40 ..
NeilG40
Quote from: Karlos the jackyl on March 30, 2012, 09:44:07 PM
Enjoy!
Reg: J5
Owners Comments: Little dissapointed , now its no longer a daily driver I will have time to fix
Still haven't got around to that :-[
Quote from: djtez on March 30, 2012, 10:18:13 PM
Nah- Vince loads cars up just off idle... which is pointless and far from ideal for a modified G40. Hence Club G40 haven't been back!
Though to be fair, in the case of my car it was 9.3:1 compression and the map PSD had given me to run in it had extremely aggressive ignition timing. Stock ignition map would've worked fine.
djtez
least it has all been a learning curve and you's both are far wiser from it !
and WE all benifit from it !!
If Steve Pitt's alledged "stocker" makes 136 horses, what does that make Steve Pitt, the accuracy of the rollers or VW's quoted 113horses ? LOL!  Pity the only other stock set-up didn't make it onto the roller`s.
Karlos the jackyl
Quote from: scotsjohn on March 31, 2012, 03:56:17 PM
It was an ex cup cup  , those sort of figures are common for a "standard" car.
type-r-dunk
Wow this is an old rr day wright up, only 8 years late :). I'm supperised some of you have still got the same cars.
Wow NeilG40 I cant believe you have still not checked you timing :0
Dunx
NeilG40
I'm trying to think if that was the last time I drove the car.
To think I took it off the road and got a passat tdi because I was working further away and it was costing me too much in petrol, how much was petrol back then compared to now?
Quote from: type-r-dunk on March 31, 2012, 10:19:14 PM
At least me, James Bartley and Neil still have the same cars and I think that Barney, Stu and Duncan still have theirs too.
djtez
if hes anything like me hes lying to under estimate the car..
i still say aw its standard! even whilst im raving new golf gti's etc .. lol
also, most things seem to make suspiciously high figures on Stealth's rollers, another reason we've not been since.
I still have the same car I had back then, I went to that day with Paul Borthwick, I can't remember why I didnt take my own car now.
hardchargin40
Haha, Richie K's G40-G60 made that power on my stock ish G60 G-lader.  If only he hadn't blown his super ported one to bits, he'd be over 200bhp (On vince's optimistic RR).
Always had 168bhp in my head for what mine made, not 176, still at 6600rpm though  :( What a crap torque figure too!  :(
Oh well, never mind.   :D ;D
86C
Ah... My old Mk.1 Polo got a mention  :)
That engine still lives on in a Mk.3 but sadly the car is dead  :(
