lightning steel toothed pullies?
Started by mario-g40, March 09, 2012, 09:56:50 AM
mario-g40
would it be possible to drill holes in walls off pullies theres lots off space to drill many holes or could de be out off balance a bit like lightning a fly weel do no if its as importing beying in ballance like flywheel?
Chris_J
Leave them well alone, you'll end up making a right mess and save yourself bugger all weight.
mario-g40
im not just gone drill some holes with handon drill i was gone doe it at my work with cnc millingmachine or with cnc plasma or lazer cutting machine,you think not worth the effort,pete on here was saying its better with lighter pullies
better off looking for some psd pullies that are aluminium
mario-g40
just got a set from bar tec, are the same from max rpm with the shyney sides
Raw
Do it!
It will definatly make your car rev more freely and make extra PSI due to the lower mass to weight ratio.
Also try drilling hoeles in your wheels and tyres for more weight reduction.
I'm going to drill out my steerting wheel so it's quicker to turn and will give better miles per gallon.
Ahhh, the old mass to weight ratio.
Did you fit that gravity controller I sent you? Downforce n ting is baaare good in the corners now.
A degree of gravity ain't no bad ting. How much for a controller?
mario-g40
can close this topic,found machine shop thats going to make them like my bar tec ones but in allu
ereeiz
Get a price for a set of ten or something. You may find there's A LOT of people on here that want Ali toothed pullies.
If you want the grief of doing a group buy that is! :D
