performance parts
Started by grungeisdead, March 08, 2012, 12:36:15 PM
grungeisdead
G40 ISV - £30
G40 Throttle Body £50
G40 Alternator - £40
G40 Front Grill Badge £25 (fins broken off back)
G40 Front Grill Badge £35 (all fins OK)
G40 Rear badge (Missing Pol so says oG40) - £25
G40 Inlet Manifold  x 2 - £30 (each)
G40 Exhaust Manifold - £30
G40 ECU with 250kpa MAP sensor fitted - £140
G40 Driveshafts complete with CV's - £80
G40 ATV Gearbox - Recently rebuilt by previous owner, not run since - £300
Piper 272 Cam - New, fitted but engine has not been run - £150
Rover Intercooler - £25
Mk1 Golf GTI Oil Cooler & Lines/Mounting Bracket and Oil filter housing (the housing is 8v gti specific, you will need a sandwich plate for operation in a polo) - £20
front lower strut brace - new - £25
rear lower strut brace - new - £25
Powerflex? (Purple) ARB Bushes - £20
Porsche 944 speedometer - £25
Porsche 944 dash console - £25
VDO oil temp guage  - £20
VDO oil pressure guage - £20
VDO volts guage - £20
Cheapo Boost Guage - £10
Mk2-3 Single Wiper Conversion - £50
RPM Stage 2 Power Kit (Chip + 68mm Twin V-Belt Pulley) £80
Lucas 54 Calipers stripped for powdercoating + seals + pistons and bolts (no carriers) - £40
63mm iirc oil pressure gauge nos - £15
VW Polo and Lupo OEM watercooled oil coolers. - £20  each ( 2 avail )
Brand new mini radiator (top fill) - £20
G40 Clutch & Pressure Plate - £30
Helix Paddle Clutch (Friction Plate only) near new - £150
15x7 and 15x8 Borbet BS with 195/45/15 Eagle F1 Tyres - £400
Cobra Fixed Back Bucket seats - £130 for the pair
Lots more bits to list as I catalog parts at the unit
Prices do not include postage, collection is preferred. I am in Central Manchester but travel to Bolton, Macclesfield, Derby, Northampton regularly so may be able to deliver bits en route
cheers,
Saf
grungeisdead
also got
1.4 vw engine cover (with brackets) - 35
1.0 vw engine cover (with brackets) - 35
6n Smooth Rocker Cover x 2 - 25 each
6n Smooth Rocker Cover (with tb cut out) - 20
Large FMIC (will get measurements) new - 80
G40 TCA - Brand new - offers over £120
Several front anti roll bars - collection only 15 quid
Chrome Bumpers - Mk1 Polo - Damaged - 80 for pair
Momo Team 300mm, new, horn press and all fittings - 120
1982mk1
#2
Hi buddy.
Is the cam designed for the G40 engine and whats the spec?
And how much posted to Norfolk?
Ill have it if alls ok.
Cheers.
grungeisdead
I have a reciept from Piper cams, stating Piper 272 G40 Camshaft, so I would assume its G40 specific. If it was an N/A 272 cam I would used it for my turbo application.
Postage would be 10 pound via courier
reciept will come with cam
1982mk1
yeah makes sence  ;D
is paypal alright?
grungeisdead
poopal is fine - yousafn@gmail.com
please add on fees if not paying by a gift, think its 4 percent odd, otherwise bank xfer is fine.
can have it out on monday morning, so will be with you on tuesday
1982mk1
randombadger69
I'll take the grille badge with tags if you still have it?
I havn't forgotten that window reg, I just seem to forget everytime I go up my unit!
grungeisdead
Money recieved for Cam, thanks.
Grill badge is yours fella, and cheers, reg would be much appreciated!
randombadger69
grungeisdead
6 quid should cover packing and postage 1st class recorded
do you have any pics of the bucket seats Saf?
grungeisdead
Not to hand mate, one is still fitted in the Mk1 Golf, the other is removed.
Got to weld up subframes Friday for the new seats, so I will take some pictures for you tomorrow Paul
what colour(s) are they?  Are they skinny-bastard only ones or will they accommodate the huskier gentleman? :D
grungeisdead
black, one tear on drivers side bolster. id fit in it with room to spare, but were not really a fair comparison! feel free to nip down at the weekend and check them out if you want, otherwise i can measure them up tonight
