Author Topic: Smaller charger pullies and chip?  (Read 4803 times)
Offline retrowagen1234
« on: November 03, 2008, 07:55:48 am »
where do i get these?  i keep hearing that people are running a smaller charger pully.   and also do i NEED the chip too?   if so how much are they?   been searching but my german is crap   :D
cheers guys ;D
Offline G-spot
Re: Smaller charger pullies and chip?
« Reply #1 on: November 03, 2008, 09:10:11 am »
You'll need to buy a chip and pully that are matched to be honest, if you nake the mistake of fitting just a smaller pully then you'll run rather lean on boost and result in warming you inards until they start fighting for space(pistons will eventually sieze in your block) leaving you with an expensive repair bill.
« Reply #2 on: November 03, 2008, 09:31:06 am »
you shouldn't run lean. the stock ecu still uses the map sensor to increase fuelling enough, you just wont be getting the best out of it.  I had a 65mm pulley and stock chip in my g40 for a while.  But yes you are definitely best off doing both at once.
« Reply #3 on: November 04, 2008, 07:59:15 am »
ok that makes sense .   :)    anyone know where to buy em?
Offline Phil
« Reply #5 on: November 04, 2008, 11:20:12 am »
I can do you a chip, and a 65mm toothed or multi v belt conversion kit.
« Reply #6 on: November 04, 2008, 05:29:19 pm »
how much for dude?   not sure on ordering from germania  ;D
