Removing side trim/bump strips
Started by Andy, March 05, 2012, 07:34:30 PM
Okay, so I know it's stuck on - but what's the easiest way to remove it after 20 years? I stood on the strip on the driver's side and it wouldn't budge, and I'm a fat bastard!
Might be lazy and leave it to the bodyshop.
if you look underneath at the rear, there is a divit... they are actually 2 piece.  The top bit should lever off, unclipping, then the bottom bit will be more like a strip on the door.  Boiling water on that
Etches
I've spent hours removing the tar they leave behind. Painstaking work! I did what pete says but had to use bug and tar remover for the adhesive.
gaz g40
What stuff is best to stick them back on with? Sorry for the hi jack
Jacque
i used original VW "double face" it's called in French/Dutch  got it from a mate who works in a VAG garage.
like the word says, is a strip wich sticks on 2 sides. (yellow cover you have to peal off)
no complaints, have it now one for about 7 months.
