removing injectors from inlet manifold
Started by ashmang40, March 05, 2012, 06:31:46 PM
ashmang40
hello i need to take injectors out of inlet manifold (i think they are the right terms? how do i go about this?? are they like a push fit?? and how do they go back together do they need sealing somehow, i have lack of knowledge lol thanks
AlexG40
Remove the metal clips and the fuel rail and they pull out. They can be a bit stubborn and you'll need new o-rings when you put them back in. If one is stuck, take your time and try to coax it out rather than pulling with all your might.
cheys03
You're right, they're a push fit. An o-ring seals the injectors into the inlet. Be careful to pull them directly out, as if you lever them out at an angle there's a risk of pulling off the pintle caps, spacer and o-ring. Fuel rail side is again an o-ring.
Refit is reverse of removal - but inspect the o-rings for any damage first and replace if necessary.
Edit: Pipped by Alex!
ashmang40
ok thanks very much for your help, i have now removed them and will replace the o rings when i refit them thanks
