Spark Plugs
Started by Chris_J, February 29, 2012, 10:07:44 AM
Chris_J
I bought a new set of NGK plugs off eBay for the g. I know that the correct NGK equivalent of the Bosch W4DP0 is the NGK BP7EVX.
However, I saw these on eBay and didn't notice the code was different. I think that they'll be okay, as I think the P may just stand for Platinum, but I want to be sure before I put them in. What you guys think, do they need to go back on eBay?
http://www.ebay.co.uk/itm/190638328863?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Yeah im sure the P is for platinum. My new spare plugs are the same from ebay but got platinum written on the box.
I'd probably stick them back on ebay Chris, it's the platinum-ness that is the unique bit about plugs for a g40.
Chris_J
The seller sent me this:
He also described the following to me:
"B relates to the thread diameter, P means projected insulator, 7 is the heat rating, E is the thread reach and VX means platinum"
Seems ok??
hmm not sure then.  probably ok if it's a standardish g40.
Chris_J
Cool, cheers Hayes.
Only mod I intend to do is a reduced pulley. Not after big power, so everything else is staying stock.
I was just shitting my pants after seeing what happened to Dirt!
