Now able to offer the Bilstein B12 spring and shock kit. This will lower a G40 20mm, and a normal polo 35mm. An excellent kit with what is probably the best ride quality around. This combines the B8 shocks with eibach springs.
£470 delivered.
"Two of the biggest names in the tuning world have joined forces to create the ultimate handling enhancement, the jointly branded Eibach and Bilstein B12 spring and damper package.
The two German suspension giants have enjoyed a close working relationship for decades, with countless OEM, motorsport and defence applications rolling on bespoke suspension packages tailored to precise client requirements. The new B12 kits put the same levels of build quality, fit and finish within the reach of the average enthusiast.
The B12 packages consist of four Eibach springs and four matched Bilstein dampers, making for the ultimate ‘real-world’ handling upgrade that balances unparalleled ride quality with exemplary handling and poise.
The springs have been pre-stressed, shot peened and tempered, before receiving a two-stage zinc-phosphate and electrostatic epoxy coating for a long and durable life. The dampers are of a superior monotube gas and oil design (most OEM units are twin-tube). The springs come with a comprehensive 5 year, unlimited mileage warranty and the damper units with 2 years. As one might expect from these two Teutonic titans, full TUV approval for every single application comes as standard.
The combined effect of the complete B12 kit is a car with less body roll that corners with vastly improved dynamics. Thanks to reduced squat and dive, acceleration and braking characteristics are also often enhanced."
Now as Eibach do not create a a kit that lowers more than 35mm, I have create what I call the B13 kit. This combines the B8 monotube dampers above, with a set of KW 60mm lowering springs.
KW also put alot of R&D into their suspension and spring ratings, and from experience usually run a softer rating than others enabling the decent ride quality from a lowered car. The B8s paired with the KW springs create an excellent kit that puts shame to the H&R cup kits of similar money.
£470 delivered.
![](http://img.photobucket.com/albums/v609/philj/bilsteing402_zps68cdcad4.jpg)
![](http://img.photobucket.com/albums/v609/philj/bilsteing401_zps70c7ee74.jpg)
![](http://img.photobucket.com/albums/v609/philj/b12g40_zps8d056b82.jpg)
