Track Prep Project
Started by Robin, January 29, 2012, 06:51:41 PM
Robin
He does offer the service however he will not do Alcantara again as its too time consuming due to the lack of stretch it gives and it also tears easily.
dub-disaster
Did you make your own rear door cards or just carpet over the inner quarter panel ??
Robin
I used some perspex to create a flat surface and then carpetted over it.
dub-disaster
Looks good, i always think standard rear door carss look abit odd in a stripped out onterior as therr ebds dont line up with anything, did you just screw the perspex back to the inner quater panel??
Robin
Quick update:
Fitted a roll cage to the car, picked up a safety devices one from a member on here for a very good price.
Had to cut the cage down to get it to fit as mine has a sunroof and i didn't want to cut it out.
The side bars are way too low so the plan is to have some bars welded in higher at a later date.
Got the cage and the welding done for less than £400 so pretty pleased with it.
Going to do Oulton Park near the end of June.
jez1272gt
Looking good mate. Be careful of the clearance between your head and the joints/bolts on the cage where the bar over the door meets the B pillar roll over bar. A friend of mine went out in a car with a bolt-in cage similar to yours and wasnt wearing a helmet, needless to say he did himself no end of damage when the car had a small bump...
Etches
Looks great that robin awesome job! gettin proper track spec now!
Quote from: jez1272gt on May 30, 2012, 10:36:20 PM
you've obviously never met robin, and he's not shown the blocks of wood bolted to the pedals mod in this build thread, or the cushion on the bucket seats to see over the steering wheel - suffice to say he's about 4ft6.
When stood on a phone book...
Once you've sorted the door bars and windscreen bar it won't be that bad tbh! Did the blot in bar to the floor fit okay?
DMWG40
Well done, looks very nice good job  :)
mark_crox
That looks really good.. :)
Are you able to pass on the details to me of the guy that did your steering wheel? would like to see if I could have mine covered..
Mark
Etches
I think his mrs did the steering wheel Mark :)
Robin
A guy at work did the steering wheel for me. PM me if you want one of yours doing.
Robin
#58
It's been a while since I have updated this thread so here goes:
Did a track day at Oulton in November and found boost issues - boost was dropping down to 17psi (actuator pretty much set to the max and no boost leaks). Replaced the turbo and boost was back up to 21psi.
Put the car on the rollers in Feb and made 205bhp.
Following that I then did a track day at Oulton Park in March and had some great tussles with cars with much more power.
Videos and pictures here: http://www.polog40.co.uk/forum/index.php?topic=9551.0
The day ended just after lunch when I stripped 5th gear.
Over the next 2-3 weeks I will be taking the engine out to fit a replacement box with the gripper diff fitted, sorting a few small oil and coolant leaks out, fitting some PPP adjustable TCA's and these FK coilovers with custom springs (300lb/in on the front and 200lb/in on the rear).
The aim is to have it all done ready for some Santa Pod action on the 10th of August - time to dig out the drag slicks :-)
Next track on the plan is in November at Oulton Park again unless I can find some time to do one earlier as I would really like to see what difference the coilovers have on the handling of the car.
Etches
Congrats on the power figure Robin, rear coils are a bit of an arse if they are off a mk1 golf? Should be ok as you've removed the helpers but will have to run them pretty jacked up.
