Track Prep Project
Started by Robin, January 29, 2012, 06:51:41 PM
Robin
After riding out in Yoof's Polo at Bylton and doing a track day last year at Oulton in the Polo I have decide to strip the Polo out to fit some bucket seats and harnesses. A full PPP roll cage will be going in at a later date.
Pictures will do the talking:
Start of strip.
Got bored of the stripping so I fitted my new Ally rad and new braided turbo oil drain.
Decided to move the battery to the boot.
Some homemade door cards.
Setting up the position of the seats.
Seat frames tacked in.
Seats trial fitted.
Once happy the frames where then properly welded in. Got a guy from work to weld the drivers side in and gave me a quick lesson in welding so I did the passenger side.
Sorted out the harness mounts.
Next stage was to spray the mounts black and then to put the carpet back.
Trimmed some carpet for the rear bench, still got a few bits to tidy up and some bits need cutting for the rear turrets, will be doing that next week sometime.
Alex
If you're tracking it I'd get those harnesses mounted properly (on a strut brace or roll cage) or you'll do yourself an injury if you crash, with them being that low down. Looks good otherwise though!
AlexG40
Looks like the Alex's are giving Robin safety lessons, lol. I just posted about the same on FB. Yoof had a decent bar that could be welded in, before they talked me into the cage....bad boys.
Robin
Thanks for the comments and advice guys. Never really thought about the danger in having the harnesses mounted low down.
Quote from: Alex on January 29, 2012, 07:52:16 PM
The angle is probably within FIA spec to be fair:
Robin- have you used spreader plates under the floor for the rear mounts behind the seat?
Robin
AlexG40
I think 45 degrees is the max but the 10 degrees is preferred. The bar between the struts at the back is perfect.
Etches
Awesome job Robin, rad looks nice too is that one that you were on about in the other thread?
G40 AD
Looks like some good work Robin, glad you're keeping tidy inside rather than fully stripped ... functional and fun! looks good!
Ad
haha, your car will look like mine soon muaaahahahaaa
Robin
Quote from: hayesey on January 30, 2012, 09:16:42 AM
lol - i do have an angle grinder now so you are probably right.
samg40
Quote from: Robin on January 30, 2012, 12:36:15 PM
What about a good selection of hammers?
Car looks good though Robin. You've not left much room for tall passengers!!!  ;)
Robin
Lol @ hammers!
Not much room due to me being a short arse!
AlexG40
Too right, build it for the driver.
Etches
I assume your going to get your sunroof welded up if you get a PPP cage robin?
