Author Topic: Track Prep Project  (Read 31962 times)
Offline Robin
  • 194bhp - 1341 Turbo
Track Prep Project
« on: January 29, 2012, 06:51:41 pm »
After riding out in Yoof's Polo at Bylton and doing a track day last year at Oulton in the Polo I have decide to strip the Polo out to fit some bucket seats and harnesses. A full PPP roll cage will be going in at a later date.
Pictures will do the talking:
Start of strip.
Got bored of the stripping so I fitted my new Ally rad and new braided turbo oil drain.
Decided to move the battery to the boot.
Some homemade door cards.
Setting up the position of the seats.
Seat frames tacked in.
Seats trial fitted.
Once happy the frames where then properly welded in. Got a guy from work to weld the drivers side in and gave me a quick lesson in welding so I did the passenger side.
Sorted out the harness mounts.
Next stage was to spray the mounts black and then to put the carpet back.
Trimmed some carpet for the rear bench, still got a few bits to tidy up and some bits need cutting for the rear turrets, will be doing that next week sometime.
Offline Alex
  • Hack
Re: Track Prep Project
« Reply #1 on: January 29, 2012, 07:52:16 pm »
If you're tracking it I'd get those harnesses mounted properly (on a strut brace or roll cage) or you'll do yourself an injury if you crash, with them being that low down. Looks good otherwise though!
Offline AlexG40
« Reply #2 on: January 29, 2012, 07:54:10 pm »
Looks like the Alex's are giving Robin safety lessons, lol. I just posted about the same on FB. Yoof had a decent bar that could be welded in, before they talked me into the cage....bad boys.
Offline Robin
« Reply #3 on: January 29, 2012, 08:03:29 pm »
Thanks for the comments and advice guys. Never really thought about the danger in having the harnesses mounted low down.
« Reply #4 on: January 29, 2012, 09:20:33 pm »
The angle is probably within FIA spec to be fair:
Robin- have you used spreader plates under the floor for the rear mounts behind the seat?
Offline Robin
« Reply #5 on: January 29, 2012, 09:50:30 pm »
Offline AlexG40
« Reply #6 on: January 29, 2012, 10:01:34 pm »
I think 45 degrees is the max but the 10 degrees is preferred. The bar between the struts at the back is perfect.
Offline Etches
  • Still got the G...
« Reply #7 on: January 30, 2012, 12:18:45 am »
Awesome job Robin, rad looks nice too is that one that you were on about in the other thread?
Offline G40 AD
« Reply #8 on: January 30, 2012, 07:34:01 am »
Looks like some good work Robin, glad you're keeping tidy inside rather than fully stripped ... functional and fun! looks good!
Ad
« Reply #9 on: January 30, 2012, 09:16:42 am »
haha, your car will look like mine soon muaaahahahaaa
Offline Robin
« Reply #10 on: January 30, 2012, 12:36:15 pm »
lol - i do have an angle grinder now so you are probably right.
Offline SamG40
  • Take.... on.... me....
« Reply #11 on: January 30, 2012, 12:55:18 pm »
What about a good selection of hammers?
Car looks good though Robin. You've not left much room for tall passengers!!!  ;)
Offline Robin
« Reply #12 on: January 30, 2012, 06:32:21 pm »
Lol @ hammers!
Not much room due to me being a short arse!
Offline AlexG40
« Reply #13 on: January 30, 2012, 06:39:08 pm »
Too right, build it for the driver.
Offline Etches
« Reply #14 on: January 30, 2012, 07:12:17 pm »
I assume your going to get your sunroof welded up if you get a PPP cage robin?
