Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Engine and Transmission
IDLE AND BOOST PROBLEMS
« previous
next »
Pages: [
1
Go Down
Author
Topic: IDLE AND BOOST PROBLEMS (Read 3260 times)
retrowagen1234
on:
October 31, 2008, 12:34:58 am »
Hi im new to owning a g40. been into polos for years tho
so hi im Dan
just bought a 91 dutch import g40 1 owner from new full vw service. 88,000 km . its developed a bit of a lumpy idle and occasional stalling. and occasionally it doesnt pull very hard. say acceleration in second and it will pull hard then go lightly jumpy like its missing
but not that extreme. its a very soft jump allmost like the feeling of wheel hop but i can feel there is less power. im wondering along the lines of fuel supply? i.e filter? any ideas guys?
Administrators
Housewives heart throb
Re: IDLE AND BOOST PROBLEMS
Reply #1 on:
October 31, 2008, 08:37:11 am »
sounds like an ignition problem - the spark is strong enough for idle but perhaps not under boost. are plugs, leads, coil, rotor arm, distributer cap quite new?
G-spot
Reply #2 on:
October 31, 2008, 09:40:57 am »
I'll second Pete on the plugs/ignition, also check the lamba sensor too, sometimes they can get contaminated with oil and stop working effectively.
When I did some of the engine mods on mine I found that the spark which worked fine in normal tune was causing a miss fire under greater load. So I tweaking the plug gap in a thou' at a time it soon cleared.
retrowagen1234
Reply #3 on:
October 31, 2008, 05:26:19 pm »
ok, its got full vw service history , but looking at the condition of some parts under there it dont look like the caps been changed in a while . and possibly original leads. im gunna get the charger rebuilt. any idea how much it costs ? in regards to different states of tune? also gonna fully service it and get the cambelt changed as they lost the reciept for that so not sure on last change. better to be safe than sorry
retrowagen1234
Reply #4 on:
November 02, 2008, 11:25:54 pm »
just relised that sometimes it gets to about 4000rpm and falls flat on its face. like no boost. but then wont go any further.
it will boost strong up until then and then nothing
G-spot
Reply #5 on:
November 03, 2008, 09:03:59 am »
sounds like your boost leak in the other thread.
retrowagen1234
Reply #6 on:
November 04, 2008, 08:06:13 pm »
woo hoo just set the co2 pot too 560ohms and shes sweet as
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
