what's your setting on koni's??
Started by xandyx, December 12, 2011, 02:48:23 AM
xandyx
i recently bought one more G, one registration, 100k miles, no engine for 400€ (~300£) and has koni yellow shocks, and i don't know which is the best setting to use with apex springs.
does someone has a similar shock/spring combo? what's you adjustment like?
i don't want to go too stiff, but also don't wnat a bouncing car. don't know if i set them half stiffness, will be too stiff and apex springs tend to be harsh!
let me know your opinion.
cheers
André
i use konis,
if they are new - set them on softest... then try them.  On the roads here (not that good quality) soft is fine!
DaBigGinger
I've got 1 turn on my front, 1 1/2 on the rear which seems to work well for me. I probably wouldn't have them any harder than that tbh. I'd probably still be quite happy with them a little softer  :)
xandyx
thanks for your reply's. i'll try them with 1 turn both front and rear and see how do they work.
i'll let you know then!
cheers
