Author Topic: Eaton charger vs Jabba sport r1 charger  (Read 7285 times)
Offline matthg40
« on: December 06, 2011, 10:10:40 pm »
Evening all very quick question which or the two superchargers mentioned above is goin to make my polo quicker.I've been offered a straight swap as I've always wanted an eaton on my polo but i just want to check its the right move to make Many thanks matt
Offline Justin14100
Re: Eaton charger vs Jabba sport r1 charger
« Reply #1 on: December 06, 2011, 10:22:30 pm »
an R1 spec G-Lader won't make a huge difference, but don't read that as no difference. Eaton can push HUGE power, but they are hell to get setup and working as well as the G-Lader or a turbo setup.
Offline matthg40
« Reply #2 on: December 06, 2011, 10:32:44 pm »
Humm don't know what to say to that realy don't know what to do if I'm honest
Offline Justin14100
« Reply #3 on: December 06, 2011, 11:28:43 pm »
What do you want from your car?
Offline matthg40
« Reply #4 on: December 06, 2011, 11:46:55 pm »
A sweet sound and power if I'm honest
Offline Justin14100
« Reply #5 on: December 07, 2011, 12:22:34 am »
An Eaton will get you there with more sound and potentially power., but the R1 is bolt on, run some toothed pulleys for a different sound and a little extra juice. Eaton conversions from what I have seen are always big hassle and take ages to get running right, if you love tinkering and making things work it might be your thing.
Offline matthg40
« Reply #6 on: December 07, 2011, 12:55:33 am »
 Already have rooted pullies and g60 injectors so is there goin to be much difference
Offline Jezza-7
« Reply #7 on: December 07, 2011, 01:55:16 pm »
Only good thing about an eaton charger is you dont have to spray the grease for boost mod into it, less maintenance and the blades are teflon i think.
But i hate the sound of the eaton charger. Sounds like a gay police car.
Offline matthg40
« Reply #8 on: December 07, 2011, 02:55:31 pm »
Ah do they sound that bad then my r1 is noisy but I think it's the toothed pulleys and they sound kool
« Reply #9 on: December 07, 2011, 03:39:48 pm »
eaton sounds totally different, personally I hate the sound of them and I think I'd end up wanting to set fire to the car after a long motorway journey with that awful air-raid siren screaming noise all the time!
What eaton charger is it?  Assuming an M45 then it'll make more maximum boost than a G40 G-Lader will.
Offline matthg40
« Reply #10 on: December 07, 2011, 04:15:24 pm »
Yes mate it's the m45 can't believe they are so noisy
Offline poloeatonm45
« Reply #11 on: December 07, 2011, 09:23:39 pm »
I have ano eaton charger and can safely say the are a pig to set up and they are really noisy but i love it i love the noise it makes and most of all i love the power i get from it i run the smaller of the 2 toothed pullys that psd made 24 tooth i think it is and the power is unreal my car now scares the crap out of me and i love every minuite off it but if you dont want to be looked at everywhere you go the eaton is not the charger for you lol
Offline matthg40
« Reply #12 on: December 08, 2011, 12:03:40 am »
I like the sound of this mate can you still get the smaller pulleys now
Offline GR40
« Reply #13 on: December 09, 2011, 09:15:11 am »
My Eaton conversion took just minor to none setup and I went up to 143hp (standard engine) and I really love the sound of an eaton despite the comments I have heard from time to time (cat under the bonnet, firetruck, electric screwdriver). I even miss it now that my G40 is broken (chassis broken, not engine), I miss the torque pull out from 2500rpm too!  :'(
Offline Jezza-7
