Front Fog light switch???
Started by Dan:), December 06, 2011, 07:10:45 PM
Dan:)
Was there a seperate switch for the front fogs or was it connected to the rear system?/
Only asking as I'm fitting fogs to my Polo.
cheys03
The switch is two-stage.
1st stage - front fogs
2nd stage - rear fogs (& front fogs?)
Underneath the bonnet near the fusebox you will find a white 2-pin connector, usually clipped onto the engine bay-scuttle bulkhead. This is the feed for the front fogs - wire your fogs into here and you're good to go.
type-r-dunk
So is this white plug a low Amp rate to switch a relay or can it be connected direct to the front fogs?
Cheers Dunx
cheys03
I'm sure it's straight to fogs, but I'd personally run a relay anyway
Dan:)
Thanks I'll make the loom up and fit them when the new ones arrive either today or tomorrow :)
