Spacer adaptors (Drums)
Started by Dan:), December 03, 2011, 06:48:04 PM
Dan:)
Can you put hubcentric spacers/adaptors on rear drum brakes or do you need to convert to discs??
cheys03
Yes, you can use spacers with suitably longer bolts.
Have you considered some of these:
http://www.axlespacers.co.uk/
Dan:)
Thanks is the only way to adapt the rear drums to 5 stud by changing the shoe's cover with a 5 stud mk3 version or would that be too large??
Dan:)
Or would I have to get the holes filled and redrilled?? If so do you know anyone who does that in Rutland area??
youngprodigys
use a mk3 golf rear drum setup! its a common conversion for better rear brakes as there large and will come in the 5x100 you desire
Dan:)
youngprodigys
might be passat drums... i know you can get some 5x100 drums whatever they are off anyway
Dan:)
I'll have a look at scrappy get 1 measure up, then if fits buy new ones.
