mk3 G40, mk2 coupe S & few 6n parts , this is whats left everything must go.
Started by leeg40, December 01, 2011, 04:48:07 PM
leeg40
Hi guys and girls, right as most of you know by now I have srtipped my fairly high spec mk3 G40 and a mk2 coupe S and this is the list of whats left after my previous sale thread erlier this year (as it was 5-6 pages long i thought it easier to start a fresh thread).
All prices are including postage (to UK mainland only, if your outside this drop me a pm and I'll try to sort you a postage quote) or all parts are available for collection from Suffolk on request for a reduced price.
If you are buying multiple parts, as long as I can get all the bits in one sensible sized/weight box you will only pay the relevant postage for that parcel, please contact me to discuss this further if required.
Dont be affraid to hit me with offers people, i need to clear the space in my workshop and garage to make space for other projects/DIY so whatever is left after christmas will most likley get ebayed or dumped, so make offers as all prices are negotiable.
VAG Mk2 Coupe S drive shafts (both sides, they have surface rust but work as they should) £10 each or £15 the pair.
VAG 085 gearbox shim plate £5. 2 available.
VAG Mk4/6n polo full stock suspension set up (struts, springs the lot) £40
Brand new sytec Motor sport inline fuel pump 234L/h @ 3Bar £110.
Brand new Forge Motor sport polished alloy header tank with cap £75. (this is a early mk2 golf tank so has no sensor provision built in, and fitment is fairly universal if you mount it yourself)
Brand new Mk4/6n polo badge less grill (plastic frame with silver mesh insert) £15.
Brand new set of 8 genuine VAG G40 hydraulic followers £90. (VAG part 034 109 309 AD)
Used set of 8 G40 hydraulic followers, only done 60k £15. (As above)
VAG G40 exhaust manifold good condition no cracks £30.
VAG G40 header tank and cap £6. (VAG part 357 121 407 C and 357 121 321 A)
VAG G40 pressed metal ring (cant for the life of me think what its for, 3 bolts hold it in place and its about 3" diameter) anyway its powder coated gloss black £4. (VAG part 030 121 048)
VAG G40 oil splash guard (head, internal) £4. (VAG part 030 103 478 B)
VAG G40 oil pressure sensor £4. (VAG part 056 919 081 C)
VAG G40 radiator sensor £5
VAG G40 DP/Cat bracket & hanger £5.
VAG G40 inner driveshaft flange guard £5.
VAG Mk2 polo MH engine alternator bracket £8. (Useful for G40 turbo conversion maybe?) (VAG part 052 199 185 C)
VAG Mk2 polo Coupe S rocker cover bolts, washers & rubbers, set or 3 £8 (VAG part number for rubbers 030 103 533 A)
VAG Mk2 polo Coupe S pressed steel rocker cover £12. (some surface rust but no deep pitting)
VAG Mk2/3 polo upper gearbox mount and bolts £5. (NO RUBBERS, ready for powder coat?)
VAG Mk2/3 polo lower rear mount bracket and mount plate £5. (NO MOUNT)
VAG Mk2/3 polo engine mount + bolt + big washer £5. (VAG part 867 199 383 A)
Brand new genuine VAG Rear brake cylinder bleed valves and dust caps £3. (VAG part 113 611 475)
VAG G40 master cylinder and fluid reservoir £8. (VAG part for res 868 611 307 A) has surface rust but works as it should.
VAG Mk2 polo Coupe S master cylinder and fluid reservoir £8. (VAG Part for res 868 611 307)
VAG wheel brace £5. (VAG part 191 012 219)
VAG wheel brace £5. (VAG part 171 012 219 A)
VAG scissor jack £8 (VAG part 867 011 031 B) 2 available 1 black & 1 gold.
VAG G40 front wiper motor and mechanism £15. (VAG part 868 955 113)
VAG G40 stock camshaft pulley £8. (VAG part 030 109 111 B)
VAG G40 stock toothed crank shaft pulley £8. (VAG part 030 105 263 A)
VAG G40 stock twin "V" crank shaft pulley £8. (VAG part 030 1?5 255 C, ?=8 or 9 I think, VW drill a locating hole through the part number!)
VAG/Hella drivers side head light £20. (VAG part 868 941 016)
VAG Mk2 polo front indicator £6. (VAG part 171 953 049 J)
VAG G40 black "VW" boot badge (complete with the rubber cup it mounts in) £7.50 (VAG part 357 853 601 B)
VAG Mk2 polo "POLO COUPE" boot badge, chrome effect £5 (VAG part 871 853 687)
VAG Mk2 polo "VOLKSWAGEN" script badge, chrome effect but well weathered £4 (VAG part 321 853 685 C)
Mk2/3 polo NON cable adjust wing mirrors (both sides and all fittings) £20.
VAG chromed door lock mechanism £8. (rear door golf/jetta maybe) (VAG part 893 839 015 D)
VAG G40 plastic radiator surround £10. (VAG part 867 121 284 F)
VAG G40 4L washer bottle NO PUMP £6. (VAG part 867 955 453 D)
VAG MK2/3 polo grab handles, b pillar ones, pair. £4. (VAG part 861 857 637)
VAG G40 under dash trim, passengers side £15. (VAG part 868 857 921 B)
VAG G40 rear strut plastic covers and foam, pair. £5. (VAG part 867 512 135)
VAG G40 sun visors, black, pair. RH has slight split on clip bar, £10. (VAG part LH 867 857 551 A/B & RH 867 857 552 C/D)
VAG G40 dash blanking plate (for under headlight switch) £4. (VAG part 868 857 145)
VAG G40 rear lap belt and buckle mechanism £8 (VAG part 191 857 837)
VAG G40 rear belt double buckle mechanism £8 (VAG part 867 857 739)
VAG G40 front seat belt assembly + all bolts etc (pair) (Consisting of VAG part 867 857 705 B, 321 857 841, 191 857 737, 165 857 732) £10 each or £15 the pair.
VAG G40 gear knob £4. (VAG part 161 711 141 A)
VAG G40 interior light and bulb £4. (VAG part 191 947 111 C)
VAG G40 front wiper arms £8. (VAG part 868 955 706 A)
VAG G40 rear wiper arm £5. VAG part 871 955 706 A)
VAG Mk2 Coupe S rear wiper arm £5. (VAG part 871 955 707)
VAG G40 grill with black "VW" badge and a Volkswagen script badge £12.50. (VAG part 867 853 653 G and 867 853 601 A) (this grill is very good condition with all the clips intact, however its had 2 of the little vertical bars removed and a Volkswagen script badge stuck in the space)
VAG Mk2 polo hazard light switch £6. (VAG part 162 953 235)
VAG Mk2 polo rear heated screen switch £6. (VAG part 162 959 621)
VAG Mk2 polo rear fog light switch £6. (VAG part 162 941 535)
VAG Mk2 polo centre consol £10. (VAG part 871 863 241 B)
VAG G40 heated rear screen switch £6. (VAG part 535 959 621)
Let me know if you are interested,
Cheers Lee.
Dan:)
I know your breaking G40 polo's, but do you have a GT grille badge lying around??
leeg40
Quote from: Dan:) on December 03, 2011, 07:03:02 PM
Hi, no sorry i dont have any left im afraid, i did have 2 as i have had 2 GT's over the years but never run them with the badges on.
Cheers Lee.
MichaelGT
Hi there, you don't have the clips that hold back the rear seats? thanks
leeg40
Quote from: MichaelGT on December 03, 2011, 10:40:10 PM
Hi, no sorry I'm afraid I have sold them.
Cheers Lee.
RyanC
when u say rear strut plastic covers and foam what do u mean by foam? thanks
86C
What's the width of the core of that Mk.2 radiator?
Interested if it's the right size  :)
MichaelGT
do you have the cowling that covers the wiring under steering wheel? thanks
leeg40
Quote from: 86C on December 18, 2011, 11:59:34 PM
Hi, I'll give it a measure and get back to you.
Cheers Lee.
leeg40
Quote from: MichaelGT on December 19, 2011, 11:03:05 AM
Hi, no sorry it's sold.
Cheers Lee.
MichaelGT
leeg40
Core size 450 x 325mm and overall size of unit is 525 x 335mm (this does not include the locating pins on the bottom and the small return on one side).
Let me know if it's of any use to you,
Cheers Lee.
86C
