Throttle sensor?
Started by Gilly, November 02, 2011, 01:42:38 PM
Gilly
Hi guys, is the white sensor connected to the throttle body the throttle position sensor? If so do you know where I could get a new one seeing as they are obsolete from vw and gsf can't match one either? Thanks
Justin14100
Probs a new throttle body / somebody might be breaking one (in fact i  might have a spare). Its a rare part to go though.
there is no throttle position sensor.  There is an idle switch and a full throttle switch which this connector connects to.
I'd open up the cover on the end of the throttle body and check the state of the wiring.
poloandyb
did you find owt out gilly about replacement throttle switch..mines just packed up on my throttle body
Etches
Mine packed up on my old one, i couldnt even get the dam thing off so i ended up buying a new one
poloandyb
was it second hand mate????if not where did you source one from????.im going to luk in sheff nextweek see if they can recon it for me..fingers crossed
Etches
Why go anywhere other than on here for parts like that mate, ive had a few off of here
poloandyb
yeah pal im on with one as we speak,but iv also been told they are getting alittle thin on the ground these days
ereeiz
Is it just a switch? Been a while since I've looked at a TB but surely you could just get one from RSonline or maplin or the like? They normally have a code of some sort on micro switches.
